It's been a little while since I bought my lathes, but IIRC, of the three, the MicroMark is the Rolls Royce (if there is a RR of mini lathes). Although all of them are produced in the same place, it appears that MicroMark goes an extra step. I think the MM has a 1/2 hp motor, rather than 1/3 hp, and everything is setup for true inch measurements. As far as I know, all of the others are "adapted" to work on the inch scale, which really isn't accurate.
I have a Homier 7X12 and it's pretty nice. I paid $350 for it shipped. Unfortunately, they don't sell them any longer.
In the end though, they will all need to be adjusted at some time, if not out of the box. One of those sites that I gave you links to tells you how to do it. All of these machines are essentially the same machine, except for the color. Just get the one that comes with the best customer service and the biggest bang for the buck.
I do have to admit, at this point, however, that if I had it to do all over again, I'd go with the Micro Mark for the longer bed and the stronger motor. The extra bed space is nice. Not only will it allow you to turn longer things, but it will also allow you to more comfortably use a 5" three jaw chuck. This was the best upgrade that I did to my lathe.
With this chuck, I can actually "chuck" a collet fixture for 5C collets and use the 5C collets in my mini lathe. I can also chuck 2" diameter stock and have enough bite with the chuck to be able to work with it and part stock that thick.
