Greetings,
I'm still loving my SF A2, but have made an odd observation. When I run duracell or SF 123 batts, everything works to perfection. When I plug in BatteryStation batts the incandescent bulb intermittantly glows dimly.
When the problem occurs, it always on the first push of the switch. 90% of the time when I release the switch and press again the bulb goes to full brightness. About 10% of the time, the second push is still dim ( I'd guess less than 25% output). After that, all pressing of the switch provides full output. The light has to sit for at least an hour, but typically overnight before the problem occurs. As long as the light is in continuous use, no problems.
When the problem occurs, I can use full thumb pressure on the switch with no change. (This would seem to rule out lack of mechanical pressure leading to a high resistance pathway in the switch). If I let the switch go and re-press, 90% of the time all is fine again. The fact that the output fails only on the first press also seems to rule out the switch. Pop in Duracells or SF batts and no problems. This pretty much rules out the primary cause being any component in the flashlight.
Is it possible that the Batterystation batts internally build up a high resistance after sitting a while (this resistance breaks down after power is applied and released)?
The Batterystation 123s work fine in my Inova X5 and 2c/3x123 maglite.
It seems that there is some odd incompatibility with the Batterystation 123s and the unique incandescent regulator in the A2.
Any thoughts?
Thanks, TR
Any thoughts?
Thanks, TR
