geepondy
Guys I may be shopping around for a new cell phone provider. Should I take in any consideration on whether service is GSM or CDMA?
geepondy said:Regarding the 800 mhz analog, I was looking at Verizon web site and found fewer and fewer of their phones are offering it now, mainly just a couple of LGs I think.
Those meters aren't worth a rat's ***. They're mainly for show. I've seen phones work better with no or very low meter strength readings than phones with maxxed out meters.geepondy said:I'm having difficulties making calls from home which I shouldn't because I get full meter strength.
geepondy said:I have and like Verizon. I'm having difficulties making calls from home which I shouldn't because I get full meter strength. About half the calls I make are very choppy on the inbound to me but the other side can hear me ok. Verizon phone rep said possibly phone as almost three years old now but this does not happen in other places. I posted about that earlier. So anyhow will do an experiment on Saturday as my friend a verizon user is coming over so will see if can repeat experiment on his phone.
gsm bands are great if you will be travelling globally, most of the world is in gsm. if sticking within the u.s. then cdma bands will give you the best reception.geepondy said:Guys I may be shopping around for a new cell phone provider. Should I take in any consideration on whether service is GSM or CDMA?
gadget_lover said:It's hard to get the Verizon help line to document problems. We were having a simlar problem here
and they kept saying there were no other customers having problems and that my phone might be going bad. I called the next day with the same complaint, but using my other verizon line. Still got the "no other customer's having problems" explanation. I pointed out that I'd reported the problem on a different account the night before, and finally got an admission that they don't document problems in many cases. I got to a second teir support, explained that I had the same symptoms on two different phones. I got a call a week later saying they'd found a bad antenna element at the local tower. The problem went away.
Daniel
geepondy said:... I really like Verizon and the coverage I get. Do you know any shortcuts to accessing secord tier help?
