You might also be confusing the E1e, E1L, and L1. I made the same mistake. All are roughly the same size, and two of them - the E1e and E1L - use the same body. Here's the difference: the E1e is an incan and provides 15 lumens, so this might be the flashlight you originally mentioned. The E1L is the LED version, and provides 25 lumens. Finally, the L1 is roughly the same size as the E1 series, but is a two stage that provides 22 lumens max. I think this could help explain the other 4 posts in this thread.
Hope this helps!
