Lights you can bore out to accept 18650.
target size is 18.5mm, which is enough to give a sliding fits with bare 18650.
Edit: if you want to use larger diameter protected 18650. you need to bore out to 18. 9mm, which is same ID as U2.
only lights like L5, 6P, C2 has enough material.
U2 for size comp, L5 body is identical to C2 except for finish. o0ps forgot about pentagon light which bores out nicely for 18650 too.
Sorry but not taking on any boring jobs
Surefire 6P, C2, Pelican M6, TNC 3watt
