Greetings,
Recently I whipped out my Arc AAA from it's storage location on my keyring to put it to use. It looked like the LED may have been dimly lit (it was indoors with the lights on). I tried to turn the twistie, but it was stuck. I could not easily twist the head in or out. I really had to crank on the twisty to get it to unscrew. At a certain point there was a "POP" like a little pop-gun going off. The O ring had been pushed out and there was an odd odor in the air. I pushed the O ring back on, re-installed the head and all was well.
Last night I had a similar experience. I pulled out the Arc in the dark and the LED was definitely dimly lit. I could barely twist the head, but it was easier than the first experience. I twisted till the pressure released, then re-installed the head. The battery was pretty shot by then. I replaced the battery and all was still well.
It would appear that in my pocket the head is slightly tightening and inadvertantly turning on the LED (This was a big problem with my Gerber sonic). I also noticed that if the head is just twisted till the light turns off, that slight pressure on the head will cause the LED to light. I think I was victim to both of these problems. The lights were likely doing long continuous duty in my pocket.
The surprise was the pressure build up in the body. Normally when I forget and leave a light on the result is dead batteries. The water/air tight body of the ARC is unique and stores up any pressure inside. Anyway, just curious if anyone else has some thoughts or experience with pressure build up in flashlights.
In the mean time the ARC is getting a full twist after the LED goes out.
Thanks, TR
Thanks, TR
