woodfluter
- Joined
- Dec 14, 2005
- Messages
- 142
A general question, maybe too general:
What effects runtimes for LED lights with similar output?
Things that come to uninformed mind are:
1. Efficiency of LED.
2. Efficiency of voltage booster circuit.
3. Heat loss (related to above).
4. Battery's internal resistance.
A case in point. I recently got a Peak Killimanjaro 1AA light with "Snow" LED. Comparing it with my CMG's, it has slightly less throw, about the same sized spill, about the same spill brightness, hotspot wider and even more uniform but slightly less bright and less bluish. Overall lumens looks to my eyes to be essentially the same. (Yes, switched batteries around). Per various sources here and elsewhere, CMG gets about 10.5-11 hours to 1/2 brightness with alkalines; per Peak website, Killimanjaro runtime plot indicates about 8 hours at best. Yet the newer light should be using improved LED with presumed greater efficiency (yes? no??) compared to now "old technology" in the CMG.
Not sure what gives.
- Bill
- Bill
