I did build a Mag85, but I had a couple of other mags laying around not doing anything so for an easy project to put more interest into one of them I loaded it with 7 alkaline AA's and a RadioShack KPR112 (6V) bulb. I got worried about overdriving the bulb so much so I swapped it for a KPR118 (7.2V) bulb. This bulb was still bright and not yellow, but didn't last through the first set of batteries. After something like 30 min. runtime, the set of 7 batteries + adapter measure 9.9V. (FWIW I'm running the stock smooth reflector but I added a flashlightlens.com acrylite lens to smooth the beam a little.)
So my question is... is the KPR118 the best bulb for this, and how would mag bulbs work? Do they make a 5D bulb? Or I could go with a 6D bulb and add another AA to my stack. I'm trying to decide how much to overdrive these mundane type bulbs for a tradeoff between lifespan and brightness.
I carry this light in my car for use at construction sites. I also carry my Pelican M6 LED so it isn't a big problem if the bulb blows in the mag.
