Hi,
I don't do inspections in restaurants, but I have work in quality and food safety in food manufacturing for 25 years, so here is what I can tell you.
UV lights are generally use to look for rodent urine, which fluoresces under uv light (other body fluids do this too which is why uv is often used for forensic analysis.) It won't do anything for bacteria. Since the food plants I have worked in do an excellent job of controlling rodents UV lights are not normally used in the facility, however we keep on on the dock for checking incoming materials if we have reason to suspect contamination.
The swabs mention in another response don't change colors to detect contamination, you use them sample a surface then send them off to a microbiology lab for analysis. Not sure what health inspectors for restaurants do, but a lot of food plants will use swabs on a periodic basis to monitor their sanitation. In recent years a lot of this has been replaced with units that detect ATP, the energy transport chemical found in all living cells. This systems use a reaction with firefly enzyme and the ATP, which is detected using a specially designed instrument. You can tell if a surface is clean in a few seconds, but if it is dirty you don't know if it is bacteria, food residue, or a combination of these.
Typically flashlights are used in food plant inspections for illuminating all the dim and dark places where you need to inspect like the inside of equipment, under pallets, etc. I would think most health inspectors would use one the same way.
