3rd_shift
Indoor beamshot up to an 18 foot ceiling.
Item one on the left.
2c 3 watt led modded maglite;
80+ lumen output.
Lightweight, for backpocket carry.
Regulator circuit for 6 - 14 volt input.
Optimized for 3 cr123 batteries with included adaptor.
Focussable, tight beam.
Runs for 2-3 hours solid on cr123 batteries at full brightness.
"Protected" rechargeable 123's also work well.
Removable head.
$85 shipped USA.
Item 2 center left.
4 three watt led maglite;
Heavy copper plate heatsink inside head.
Designed for alley sweeping.
Back pocket carry.
250+ lumen output.
Non regulated, direct drive for cr123's with included adaptor.
2 rechargeable Pila 150a lithium ions may also work.
Runtime is around 30 - 40 minutes.
Non focussable wider, smooth, bright beam.
Non removable head.
$129 shipped USA
Item #3 center right.
3c cell 3 three watt led maglite.
Hand carry, or backpocket carry with beltring.
Heavy copper heatsink in the head.
When this light is balanced in your hand,
The switch is always right there, withing reach.
240+ lumen output on regular, unleaded c cell batteries.
Non regulated, direct drive for alkaline, nicad, or nimh c cells.
Runtime is around 1.5 - 2.0 hours on good, 5000 mah nimh c cells.
Non focussable, wide and bright "alley buster" beam.
Non removable head.
******SOLD******
Item #4 far right.
6D 5 watt led Maglite.
Abnormally high output, high efficiency, WX1T bin led.
Foot patrol, stakeout, search and rescue, hand carry.
For the bigger guys who are in good shape.
150-200 lumen output on regular unleaded D cells.
Non regulated, resistored direct drive.
Nimh, Nicad and alkalines all do great with this one.
Runtime is about 8 hours solid, on 8500mah Nimh D cells.
Focusable, tight beam comparable to a stock 3 cell maglite's beam.
But much brighter than a stock 6D's.
Removable head, for a nice 170 degree light pattern ahead of you.
$99 shipped USA
www.paypal.com to [email protected]
