Can drained 1.5v lithium AA work in Fenix L1P?
socom1970
The Heartland of America
If I drain a L91 lithium AA battery down to between 1.5v and 1.6v, can I safely use it in a Fenix L1P? Also, will the lower internal resistance of the lithium AA hurt the L1P now or in the long run?
lamperich
usually all ledtorchs with regulator needs a voltage source.
so no problem
Lite
Ontario, Can.
I haven't tried a lithium in mine, yet. I've read it is suppose to be fine, though.
Yooper
Upper Peninsula of Michigan
A fresh L91 is no problem. I've gone through three L91's in my L1P. I also have lithiums in my ARC AAA-P, L0P, L2P, and Streamlight PP Luxeon, all working fine,nice and bright, long run times, no problems.
nutz_about_lights
The Little Red Dot.
Quite a bad idea if you ask me. Drained batteries have a very nasty tendancy to leak. And if you're going to use that in place of fresh lithiums I guess the probability you'll end up with a leaked L1 is 0.99999998...
Like the others said, fresh batteries should do fine.
VWTim
Corvallis (OSU)
I thought that was one of the advantage of Lithium Primaries? That they don't leak.
carrot
New York City
Someone else posted that leaked Duracell 123As corroded the inside of their light (but Duracell did offer to replace the light), so I don't think lithiums don't leak, but a lot less likely than alkalines.
Lithium advantage over alkaline (in random order):
- work better in cold weather (but still loss of performance)
- self-discharge rate is much slower than alkaline -- that's why the shelf-life of lithiums are rated much longer
- lighter weight
- more consistent discharge curve -- voltage doesn't drop as quickly as alkaline under load
- higher voltage
- sexier looking
But they're more expensive, and often harder to find.
