zespectre
I feel like HDS has the EDC category pretty much sewn up right now but thinking about what makes a light right for a job got me to pondering what might make up the "Ultimate Camping Light". Here are some of my thoughts and I welcome others to join the fun.
-Waterproof (30 ft should be good)
-Must float
-Not too small (hard to find)
-Not too big (hard to pack)
-Plastic (glow in the dark) body or at least the bezel.
-Double barrel design (back-up set of batteries already installed. Either flip a switch or just have a "spare carrier" built in)
-Thermal protection
-Computer control (like the Gladius) that will automatically dim the light to conserve battery life.
-Momentary (signal) and constant on mode.
-Stand up on tailcap.
-Multi Level control
-Throw design, LED and deep reflector, but also with a ring of 4 to 6 of the 5mm LEDs around the bezel for flood (use either or both)
-Gripable with your teeth
-Signal strobe mode (location and S.O.S?)
-Cold resistant (say runs on CR123A batts)
-Color filters
-Low battery warning led (just a tiny red one near the switch or something)
So far what I picture is something similar to, but probably smaller than, the old "right angle" army lights but with two battery tubes inside (one for the batts in use and the other for holding the spares). It would have a rubber "tab" on the back of the head so you could grab it with your teeth if you needed to. The ring of the bezel would be made of GID material and would screw off so you could insert filters that were stored in the tailcap (just like the army light). Etc.
I really wish I had the capability and tools to manufacture at least a prototype of the thing that is in my head, I think many would really like this light <sigh>.
-Must float
-Thermal protection
-Color filters
