This is my first incandescent light in a long while (other than purchases for LED conversions).
It really is a Hybrid - a Xenon incandescent bulb for a hi-beam, and 3 white 5mm LEDs for longer runtimes - all powered by a single 3.0V CR123A Lithium battery.
The first click on the light side-switch turns the light on - this could be the xenon or LEDs depending on the last state the light was turned off. Second click turns the light off - third click turns light on with the other light "bulb" active. Fourth click turns light off -and the light alternates between xenon and LED in this way.
This light's color is supposed to be "titanium" as designated by Streamlight - but it is very silver in reality - no hint of gray at all - but because of the machining and knurling it is very attractive in alumium silver.
Advertised runtimes are
1.5 hours on Xenon
and
9.5 hours on LEDs
Size
Heads -
Twin Task 1L head is focussable for the xenon - but not for the LEDs
I was advised by LightHound (where I bought this) - that this light probably would blow if used with a 3.6V rechargeable Li-Ion RCR123 - so be warned.
Twin Task 1L on Xenon vs. Scorpion xenon 2x CR123
The Twin Task 1L on xenon Hi-beam is obviously not as bright as the fabulous Streamlight Scorpion xenon 2x CR123 (new bulb new batteries)
Compared to a 2AA Mini Mag on standard krypton bulb and alkaline AA
Visually the Twin Task 1L on its xenon Hi-beam seemed about the same level as a good 1 watt Luxeon -
Twin Task 1L xenon vs. S1801 1w Luxeon 1xCR123
vs. Fenix L1 v2.5 (Non-Premium) (fresh alkaline AA)
These beamshots seem to refute this - but indoors I seem to see about as well on the Twin Task 1L on xenon as these two very good 1watt Luxeon-I LED lights - and to me it still seems as bright even after these beamshots.
How about the LED performance? -
the light that it is most like is the Nite-Ize drop-in for 2AA MiniMag
Twin Task 1L LEDs vs. Nite-Ize LED Drop-in for MiniMag 2AA
Twin Task 1L LEDs vs. 0.5w 1AA - AdvancedMart LED-005S
Twin Task 1L LED vs. MJLED drop-in for MiniMag 2AA (gen2 my #2)
Twin Task 1L xenon vs. MJLED drop-in for MiniMag 2AA (gen2 my #2)
out of interest I compared this with my first gen2 MJLED with yellow-green tint -
The bemshots seem to show the MJLEDs at about the same brightness as the Twin Task 1L on xenon Hi-beam - but in real-life indoors I really feel the Twin Task 1L on xenon is noticably brighter - or at least I see a lot more/better.
1.5 hours on Xenon
and
9.5 hours on LEDs
Size
Heads -
