beefbowl said:
how did u do it?
i just realized u answered my question before i asked it with the previous npost. its been one of those days lol
lol np
I have those days as well..
Xrunner said:
Nice work... does the finish feel slick or have more of a rough polished feel to it?
-Mike
It has a smooth feel to it
InfidelCastro said:
That's pretty cool. Only uses 1 AAA battery? Must be really nice and handy. What kind of bulb does it use or is it LED?
It has a mjled in it,the same one that the river rock/nuwai's use..
Pellidon said:
Get thee to a Wal Mart post haste. Or rather several as these are hard to keep in stock. The plain Jane unpolished ones that is.
After buffing, did you clear coat (Krylon anodize
) or have it anodized? Did you make the reflector or find a readymade one?
I did not clear coat it,although I thought about it,I am still gonna take it a step further with the polishing,Dont know when I will get around to it though.. The reflector is from the regular Docry..
carbine15 said:
beware all that the new versions of the Dorcy AAA have no reflector to speak of. Not that they ever needed one with a full dommed 5mm led, but the lens on the new ones is a pathetic attempt at a focused beam. It provides no spill. It uses a focusing lens that just cuts the overall light from this great little gem. If i got a new version I'd probly run it without the lens at all for max brightness. I might spray paint the white plastic reflector a shiney silver and use a cut high output led like the nichia cs. I never heard of this voltage mod though.
The dorcy with the domed lens it slightly shorter than the regular dorcy,and has a white reflector,So I took the chrome reflector out of a regulare dorcy and put it in this one,the reflector is also shorter,as you may know the smjled isnt a focused led..
As far as voltage,For now I have just removed the resistor,and intend to add another boost circuit in it,Another boost citcuit seemed to work,when I hot wired it,I shall test it again and see how its gonna go...That little triple A isnt gonna last very long at all lol
Russ
