James2258-
First, Welcome To CPF!
I'll try to answer your basic question. The performance of the G2 and C2 will be identical. They use the same basic lamp assembly and batteries.
The C2 is far more expensive because it is machined aluminum, has a glass lens, a lanyard ring, a pocket clip, and a specially shaped grip.
All that said, the G2, IMO, is one of the best bargains in flashlights-a SF for under $35. Also, for some people and in some uses, the plastic body is an advantage. If it suits your budget and use, you will be very happy with a G2.
Mark
