While the 6p and 9p are very good flashlights, if you had up to $200 to spend, you might want lights with multiple functions and/or multiple brightness.
If you don't want to deal with changing bulbs or risking filaments burning out, you might want to look at LED based lights. Although there might be rare instances of problems, theoretically LEDs last many thousands of hours and are shockproof (shock, not shatter!
As others have said, it is hard to define 'best'. I would assume best for your needs, and we have no idea what that is when all the info you have provided is
"Topic in title" :laughing:
Do you want to carry it everyday? Must it be small enough to hang on your keychain? Or just pocketable? Or do you mind pouching it on a belt? Is it for indoor use? Does it need to throw far to spot things in the distance? Multiple brightness levels? Waterproof? Clicky switch (at tailcap or side?) or twisty (head or tail?)? How much runtime do you need? Is it going to get knocked around? etc etc etc...
Welcome to CPF!! :laughing:
