NEXTORCH - 300 m long-shot E6
Results 1 to 5 of 5
Thread: 9v PP3 keychain pocket rocket?
    Flashaholic MikeHunt79's Avatar
    Nov 2005
    Bristol, UK
    Default 9v PP3 keychain pocket rocket?
    Ok, I'm planning to build this from scratch. How about this for a keychain light for occasional / emergency use?
    9v pp3 (probably alkaline, maybe NiMh) battery, direct driving a lux V at around 900mA, with a resistor. I already have the Lux V and it has a Vf of around 7v. It won't be very efficient, but runtime is not really an issue for me with this light... Size is the main concern.
    I was thinking a 20mm colimator would be best... probably a 2 degree carclo one... I've already got a machined MiniMag head I can fit this in.
    Would a Alkaline be capable of outputting high current needed, or would a NiMh be a better option here? Also, I'm guessing I'd need resistors with higher current than normal current ratings.
    Also, where can I get metal (preferably alu) PP3 holders? I was hoping to make it act as a heatsink as the Lux V's get hot.
    Flashaholic* Planterz's Avatar
    Dec 2005
    Tucson, AZ
    Default Re: 9v PP3 keychain pocket rocket?
    I can't help you with all the technical stuff, other than to say that if this light is for emergency/ocassional use, go with lithium batteries. Alkalines will eventually self-discharge, can leak, can't drive much juice and don't work well when cold. NiMH self-discharge even faster than alkalines. Lithiums however can drive current hard, have a 10+ year shelf life, and work fine when cold. NiMHs should work fine for regular use, but don't rely on them for emergencies.
    Nov 2005
    Bristol, UK
    Ok, thanks... I've managed to get quite a good deal on some "Ultralife" PP3 lithium batteries, so I ordered 20. I didn't see a max current rating on the site, so I hope they will cope. Do lithiums batteries drop voltage as they are used like lithiums or do they hold thier voltage like NiMh's?
    Now, I just gotta figure out where to get a holder, and work out what resistors I'm gonna use.
    Flashaholic* offroadcmpr's Avatar
    Feb 2005
    CA
    Quote Originally Posted by MikeHunt79
    there is some voltage drop, more than a nimh, but less than a alkaline.
    Nov 2005
    Bristol, UK
    Quote Originally Posted by offroadcmpr
    Any guesses on how much drop would there be roughly at 700ma draw? As long as it doesn't go below 6v I should be ok.
    If theres too much drop, I could always use NiMh but I'd have to always keep the battery charged.
    Also, I reackon I might be able to modify an existing 1xAA torch body to accomidate a pp3.
