Hey all - this is my first post here. I hope it's not too far off-topic, but in hunting around for info about LEDs, I got quite a few hits here and saw some threads where there were people who clearly knew what they were talking about. So here goes.
I'm working on a bright LED backlight to shine through a 4" LCD panel in use as a homebuild video projector. It's not clear yet if I'll be able to squeeze enough brightness out of this setup to be able to end up with a watchable projection, but it's a fun and inexpensive project, so I'm willing to risk it.
Here is a link to the LEDs I'm using:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=7578524628
They're white Jeled 5 mm units with a claimed intensity of 40000 mcd.
I'm about 1/2 done mounting and soldering the LEDs, the array will be 18 rows of 14 LEDs, for a total of 252 units. For my testing purposes, I'm using an ATX power supply to drive them, but for the finished version I'd like it if I could switch to a more compact wall-wart type 12V supply.
I'm wiring the rows of 14 LEDs in parallel, and my initial plan was to have 3 "blocks" of 6 rows. Each block would be made up of rows wired together in parallel, and the 3 blocks would be wired in series. From the specs on the page above, these things want about 3.4V and 20 mA each, so this works out to 10.2V and ~1.7A.
My basic plan is to put a variable resistor in series with the array, and tune it until the voltage and current give me the right balance between brightness and longevity.
My questions are:
1) Does this basic approach make sense?
2) With this approach, should I be considering under-driving the LEDS to keep everything safe? Or is there room to over-drive them for better brightness? If so, how much?
3) Are there any benefits to using the ATX power supply in the finished product? It's more expensive and less compact than a regular 12V transformer, but I'd expect the power to be much better regulated.
4) How can I estimate how many lumens I should be getting out of this setup? I'm thinking it should come out close to 1000 based on the reading I've done so far - does that sound about right?
I can post photos later in the week if anyone's interested in this setup.
Thanks a bunch,
Phil.
My questions are:
Thanks a bunch,
Phil.
