Gryloc
Hi agian. I plan on modifying a new C or D maglite and I wanted to know the best configuration of batteries i should use.
I can use:
-the bulky 3D flashlight
-the more comfortable and smaller 3C flashlight
-or a fat, but short 2D flashlight with a 6XAA holder (which I already have)
Size is an issue, in a way. I dont want a huge maglite. It would be nice, but not neccesary if the flashlight uses common batteries and had a decent battery life. I have plenty of NiMH AA batteries available, but I dont feel like spending all my time charging them with my 4XAA charger too often. I could use NiMH C's or D's, but if i use either, i will have to commit to that type only. I will have to buy this more expensive battery type, then get a charger for them. I would prefer if I dont use Alkaline because on a college budget, the price of the flashlight is expensive enough, and i dont want to pay for batteries every other week. I really dont like CR123's because they are expensive and not practical for me now, especially with a light that will draw this much current.
What should I do? What is the best way of finding how much battery life I will have? I know a 2300mAH NiHM AA will provide a 1A load for almost 2.3 hours (living in the ideal world, of course). Do I compare wattage? For example, 4 lux3's (3.6V@4A, or 7.2V@2A) will consume 14.4W (or either 3.6 X 4.0 or 7.2 X 2.0). Then the 14.4W divided by the voltage of the battery set-up? So 14.4/4.5V= 3.2A per C or D alkaline battery. 14.4/3.6V= 4A per C or D NiMH battery. Finally, 14.4/7.2V= 2.0A per AA NiMH battery.
If I am completely off with these calculations, please correct me. This idea seems to work okay, I guess. They are a bit rough, but they seem fair.
I will have 4 lux3 emitters wired in either a parallel configuration (about 3.6V@4000mA) for the 3 X C or D battery set-up, or I will have the Lux3's wired in a series-parallel configuration (about 7.2V@2000mA) for the 6 X AA battery set-up. I know the 3D maglite will give the best battery life, but which is the best, most practical set up I should go with, the 3C or the 6AA?
Currently I am torn. I am stuck on which host flashlight I should go with. I just started ordering parts tonight (4 X IMS SO20XA reflectors, which should fit well).
Another route is using some sort of converter circuit ($$) that will either boost or buck the voltage (like a TaskLED Fatman-boost or one of the many Yamaguchi Consulting Converters). This would have to be a worthy setup and the converter must be able to handle all the current (even in an efficient way). The nice thing about the converter is ease of use and it will keep me from overdriving or underdriving the LEDs significantly. I want a nice output, but I dont want to damage any LEDs.
Oh, if there is another good host flashlight that I should use (similar to a maglight), let me know. The Streamlight 2D Task-light would work well, but I never torn one apart, so I dont know how it would work in there. Nice thing is that it is 1.5inches shorter than a 2D Maglite. The 3C streamlight is 2 inches shorter than the Maglite, but the head isnt big enough for 4 emitters and reflectors. I was questioning the knock-offs that you see at Big-Lots. They dont seem too bad. If anyone has any experience modding any of these lights, please let me know what you found! Cool.
Any fellow modders have any advice for me? I know this post is long. I just felt like i am stuck and I dont know which way to go with battery and hookup configurations. Any help would be greatly appreciated. Thanks!
Boy I better get to bed. Whew. All this excitement of making a powerful Luxeon cluster flashlight is wearing off.
I can use:
