modamag
It has been almost a year since the introduction of the PTS (Perfect Tri-Sink). In the LED world this is like an eternity.
I finally got time last December to do a complete overhaul of the PTS design to address the various issues that came up with the first revision.
=== Issues Commonly Brought Up ===
1. Use the PTS with 3x Luxeon V.
2. Hold the PTS down to the Mag bezel using screws.
3. E-can for the electronic converter.
4. Mag bezel height variation cause PTS to sit too high/low
5. Too much compression force from the lens pressing down the reflector causing damage to the LED.
Well, I heard all those concerns, and all of them were taking into consideration for the revision. So I took the work done on the PMS-K2 development and transfer the knowledge learns to the PTS2. I went all out with no expense spared in attempt to make a truly "Perfect Tri-Sink". So the following improvements were made.
=== Enhancements ===
1. Increase in overall mass of the heat sink. Since I can't change the width to depth ratio (standard in HS design), I tried to slap on as much material as possible to achieve the 2:1 ratio without compromising with the functionality.
a) PTS2-C (2.2oz) vs PTS-C(1.5oz) … 47% increase in weight
b) PTS2-D (1.7oz) vs PTS-D(0.7oz) … 143% increase in weight
2. Increase the surface area to bring that heat to the Mag exterior for convection and conduction cooling.
a) PTS2-C (7.170 sqin) vs PTS-C(3.969 sqin) … 81% increase in surface contact
b) PTS2-D (6.804 sqin) vs PTS-D(2.058 sqin) … 231% increase in surface contact
3. Provide an e-can for the electronics. E-Can size is based on hotlips/osink defacto standard.
4. Provide three pin hole locations for locking screw tap.
5. Threaded portion to screw down into the Mag head. This eliminates the necessity of tightening the lens retaining ring to compress the lens / reflector / LED. As an added bonus the threads will be able to compensate for the variation in the Mag bezel shoulder.
IMHO this addition is the greatest improvement for usability.
With the above enhancement I'm confident that this HS will be able to provide enough thermal transfer to the exterior surface so that we can now use 3x K2 or even 3x LuxV. The ball will now be thrown to the other side of the court, where the new problem is how do you get rid of all the heat buildup on the light exterior? Well the answer is quite simple how about some groovy head like what cmacclel have done. :wicked:
So with all that said let me present to you the latest addition … PTS2
=== Recommended Host / Batteries / Driver / LED combination ===
Mag2C / 2x18500 | C-LiIon / Fatman or Shark / 3xLuxIII
Mag3C / 3x18500 | C-LiIon / Shark / 3xLuxV
Mag1D / 4xAA / Fatman or Shark / 3xLuxIII
Mag1D / 4x14500 / nFlex / 3xLuxIII
Mag2D / 2xD-LiIon / Fatman or Shark / 3xLuxIII
Mag2D / 2xD-LiIon / Shark / 3xLuxIII
Mag2D / 8x14500 / Shark / 3xLuxV
Mag2D / 6|7xAA / Fatman or Shark / 3xLuxIII
* Listed in order of performance per size and level of difficulty
* Note LuxIII is interchangeable with K2 (when available as stars format)
=== Recognition ===
Special thanks Icarus for the design review and recommendation on the threaded enhancement.
=== Recognition ===
