Hi,
Hope someone can help. I need to light an approx 7"X7" area on a table at a distance from table surface to LEDS or about 10"-12". The LED's will be spaced about 8" apart from each other shining down at the table surface.
I really need to keep the cost down as much as possible but I do need a fairly even and bright illumination across this 7"X7" area.
My first though was to purchase 2 Invova x5's, pop the lamps out using the "ice" method I read about on this site and mount those but after a bit of expermenting, I think using two Luxeon III stars would be a more cost effective way to go.
Here is where I could use some help from the experts. If I were to use 2 Luxeons III's, which collimator lenses would work best? I think the FHS-HWB1-LB01-H($8 each) on the Luxeon star site would be the best choice? Anyone have any experience using and mounting these? ANy tips? tips on heatsink?
Also, what would the best way to power these two up. I need to do it using a 12v dc source. Which driver would you recommend keping cost in mind? I saw on ebay someone selling a driver that makes the lamps variable which would be fantastic for my appliction rather then simply on/off. Anyone have any schematics to build a variable driver or should I just spend the $10 on ebay for the kit? Do the variable drivers would good on the the luxeon III?
Any advice to do what I need to do or the best way to go about it would greatly be appreciated! I am open to any ideas!
Love this Forum.
Thanks!
Wade
PS Sorry for all the questions!
Love this Forum.
Thanks!
Wade
