I need your advice! I have a Streamlight TL-3. The problem is that sometimes the Xenon bulb comes loose in the head. I have searched this issue in the CPF forums and various others have noted the same problem.
When it first happened, the bulb quit working. I have put in the 2nd bulb and carefully screwed on the head with the batteries in and the tailcap screwed all the way, so I could judge the beam --- following the lead of another thread I found from my search. For now, I plan to leave the blankety-blank thing alone and only use the tail-cap.
The aggravating thing about this is that I loose the ability to focus the head with any degree of reliability at all.
My question: Should I contact Streamlight and see if they will do something, like replace the head? Or should I try something else?
Thanks!!
:hairpull:
Thanks!!
:hairpull:
