I like this little light overall, but it is not for everyone I suspect. Here are my thoughts.
Pros:
-Very small.
-Very comfortable - in fact, I think this is it's best feature. The straps are soft, small and easily adjusted. The center strap helps too.
-Plenty of light for household use. Nice hotspot with usable sidespill.
-High and low settings with seemingly decent runtimes on 2 AAAs.
-Nice price
Cons:
-Very blue light - quite a bit bluer than the RR lantern with the Jupiter LED.
-Low setting could be lower. Reading in a dark room is easily done, but the hotspot is a touch too bright if directed onto the page. The difference between high and low could be greater IMO
-For outdoors, I might try something a bit whiter and brighter.
That's about it. If you need a simple, cheap, household headlamp, this could work for you. If you are a serious user or use the light outdoors quite a bit, I would look elsewhere.
Pros:
-Very small.
-Nice price
Cons:
