What is the differnce between these two heads? will the KL 6 fit on my M2 body with A19 to run it off three cells? thanks! also whats the throw like on these heads?
The newer KL5's can run on 3 cells, I've heard that some of the older KL5's should not.
As far as the throw goes, it is not as good a P60 lamp, at least if I compare my KL5's to P60's. It is a more floody beam. The KL6 is tends to be a little tighter on average.
