Flakey
- Joined
- Dec 4, 2005
- Messages
- 425
Pila 168S is the proper battery to run in a g2 nitrolon correct? will this run the p60 adeaquately?
Lunarmodule said:Yep. 168S works well. P60 draws an average of 960mA of current so you get over an hour runtime with a single charge.
I don't agree with that. A P60 module has to work at a nominal voltage of 6 [v], a 168s has an average (working at high drain current) voltage of 3.6 [v]
mdocod said:any bulb will light up with just about any underdriven voltage, a P60 would probably make SOME light at 1.5V, it just wouldn't be very impressive... My G90 9V lamp will run off a single cr123 (3V)... and actually wouldn't make a bad pocket light driven by a single 17670(too yellow though)... Also- if you were to drive the P60 at exactly 6V, you would actually be overdriving it, as the lamps in these types of flashlights are designed with the foltage sag of lithiums in mind..
that said- the 3.7V lamps will be brighter and whiter than a P60 when driven by a 168s(17670)
