iamerror
Can someone explain the concept of overdriven vs underdriven? Does overdriven mean supplying a bulb with more voltage than is typical for that bulb? An underdriven light will not have good output? Thanks
iamerror said:so a underdriven luxeon led will look more like light from an incandescent?
they're referring to efficiency as amount of light per watt of energy used.iamerror said:Sorry, another beginner question... when you say "more efficient" are you saying the batteries will last longer before you need to change them, or something else? (this sounds important)
pizzle said:they're referring to efficiency as amount of light per watt of energy used.
iamerror said:Oh, thanks. Is there any advantage in having a more efficient bulb over a less efficient bulb if they both put out the exact same amount of light?
pizzle said:because the more efficient one uses less energy, it should have a longer life than the less efficient one.
