TENMMIKE
lost power about 36 hrs ago and im now just powered up. if i had thought i would be without power that long i wold have been more scientific report,
my report . lights used SF e1l, arc aaa p,fenix lop,NO gladius, my first thing i noticed was my gladius started blinking after 10 min using battery station batteries bottom stamped "1005" i tried 6 different sets all the same results(10 min started to flash), however the batteries powered my gladius at a high output for1.5 hrs and longer, turning it down just a few levels it stayed longer then i could i could stay up, A+++ for my gladius, ( note the BS batteries did well on all accounts except the high power GLADIUS test)note with surefire batteries my gladius showed no signs of low batt untill 100 min of use , im gonna use up my bs batteries and go surefire only, after this test
fenix LOP and ARCaaaP im sure everybody knows the fenix is much brighter for about the 1st hr, at about the 1hr 15 mi mark the arc caught up and they were about equal , after that the arc kicked the fenix ***. by a VERY large margin, i also ran a SF E1l during the same time as the arc/fenix test, it did a very good job and stayed bright, at the 3 hr mark the fenix was worthless, the arc was great the E1L was still very good, note i had a 4xd mag running as well but it was already depleted but it did a good job at throwing a weak yellow light for 4 hrs , better then i thought it would do so it did well in my eyes i used a SF M3T as well but nothing tested that is relevant to this episode EDIT im gonna get a SF light diffuser and try it on my gladius, i used my gladius alot and most of the time it was used straight up as a candle i cant say enough about how well it did , all the way down to super low power that worked relly well in middle of night when i set it at that when i went to sleep and it still was at that level later on
