Anyone ever think of doing this:
A flashlight that can take one of ANY AAA, AA, C, D cell battery without any extra carriers or other stuff.
It would use multiple concentric spring loaded rings that either slide up against the battery or are pushed down if the battery is too large (and they stop the cell from moving).
The battery can't slide around either as the rings are lined with foam.
The tail cap is just a flat piece of metal.
It would be really nifty I think.
An explanation:
A C cell is placed into the battery compartment, where it slides down and presses against the AAA, AA and C rings. Pushing them down into the front part of the light.
The D cell ring slides past it but the foam still contacts the outside of the cell.
There would be of course a wide tolerance voltage regulator (or even several regulators depending on voltage) to permit use of any 1.2V to 3.6V cell in a common size.
Since the light can run from a wide variety of cells it should have a few different lighting options as well, LEDs of several colours (white, red, green, amber), and several brightness modes.
This light could not be super small due to the battery compartment design, but still should only be fairly small. (like a 1D modded Mag)
Good idea or what? (assuming it can be built)
An explanation:
