I ordered a coast v10 pocket light. I saw it on amazon for $14 ,its really small,I measure 2 3/4 inch,runs on 3 AAAA.Nice stainless steel,looks good!Nice solid heft to it. It has blueish white tint, same as the new inova radiant AAA,but brighter and a wider fllood beam with good spill.Also brighter than my xnova 2cr123! Not perfectly smooth beam ,but good. Especially for indoors and close up work. Even walking around, Ill take it out tonight to dog walk. Should be ok for that. Twist to turn on/off. As for batteries it says 50 hrs! I doubt that! When i recieved it the batteries in it were nearly dead, Great, I did what a fellow poster suggested I opened up a duracell 9 v, inside are 6 AAAA batteries! Cool,now thats cheap power! works out to 44 cents per battery! They fit perfectly, just note to check polarity with a meter,the normal bump on mine were actually thr neg! weird.There is no lens just 3 leds.A nice flat bottom for candle mode.As for quality of construction not bad,the only complaint is a bit of roughness on the threads,I put some dielectiric grease to hopefully smooth things out. Overall for $14 plus shipping its a cool little pocket light. :naughty: Mine is not the 1.25 w.it is actually the eddie bower version same as avail at target for 19.99 .Hope this helps
Heres the specs from manufacturer;
Coast V10 Stainless Steel Triplex Torch. Patented crystal reflector system. 3 Diode-charged light chips. Twist on/off switch. 24ct. Gold Contacts. Includes sheath. 2-7/8" Length.
