I have a Mag 3d I want to convert to LED, but there are a few options I have to choose from.
I have a Wiz2 converter board which I want to use, but I can't decide which bin Luxeon would be best. I prefer the *WO* bins, and would like to stick to Lux III. I was thinking maybe a TWOJ or TWOH, and maybe even a UWOJ (if they even make that in a Lux III) Where can I order Luxeon LED's other than The Sandwich Shoppe?
The other problem is: should I run 3-D cells, or 4-C cells? Would the number of cells affect the bin of Luxeon I should use?
Also, would it be possible to build a PR based Luxeon while running the Wiz2 converter? (basically a home-built, regulated drop-in, like the Diamond drop-in).
Finally, would anything I built using the Wiz2 be comparable to a Diamond drop-in?
