widget said:
I'm looking for an afforable light that can run on rechargeable batteries. Fenix L1P & Nuwai Q3 seem to be the favorites here. What's better than the Fenix L1P & Nuwai Q3? Are the Jetbeam & Iota better than the Fenix L1P & Nuwai Q3?
They are both very good lights, esp. the L1P.
In that same class -- single-cell very compact lights -- two others come to mind that may be "better", but they're considerably more expensive. But first, the Fenix L1P:
- Fenix L1P: 97.7mm x 20mm (about $50) - Pros: price, beam quality, AA battery. Cons: anodizing, discharge curve with alkaline, size (relative to more expensive, smaller lights)
http://www.flashlightreviews.com/reviews/fenix_l1p.htm
- Peak Caribbean (pocket body, about $100): 73.2mm x 20mm - Pros: Quality, throw, size, run time, good regulation, anodizing. Cons: cost
http://www.flashlightreviews.com/reviews/peakled_caribbean.htm
- Fire~Fly3 (pocket body, about $130): 65.2mm x 20mm - Pros: Programmable with variable brightness levels, very small size. Cons: unknown
http://candlepowerforums.com/vb/showpost.php?p=1197747&postcount=122
Unfortunately the FF3 hasn't been shipped yet, so I can't give hands-on advice. However it's the smallest regulated CR123A light I've seen, plus it has variable output (like an HDS).
The Caribbean is very high quality, just a great combination of output, run time, throw, size and regulation.
FF3 and Caribbean are twisty switches, vs the L1P tail click switch. The FF3 will run on nonrechargeable cells but is intended mainly for (and works better with) rechargeable RCR123A cells. The Caribbean will run on either.
