PhotonFanatic
●-●-● LDO^3 Drivers -- With TX0H or TW0H Lux III -- $40 ●-●-●
LDO^3 Drivers -- With TX0H Lux III -- $40
Spoken: "LDO cubed". Dimensions: .55" diameter, .535" tall; pretty much the standard sandwich size.
Up for sale are the LDO^3 drivers designed and built by andrewwynn. These are designed to work with rechargeable CR123s and will provide the LED with an initial 800 mA (+/- 20 mA) current. As the driver warms up, one can expect the current to climb closer to 900 mA, which should offset the dimming of the LED due to heat buildup. In other words, one should expect a very even lux during the majority of battery life. As the battery reaches depletion there is a rapid transistion from 'full bright' to 'moon mode' which will last quite a while as the battery exponentially decays to the Vf of the LED (typicaly close to 2.5V).. in other words, it won't over-discharge even if left on.
On a long run, when the batteries start dying off, and the light starts to cool, due to reduced current available, the light outputs more lumen per watt and it makes for a very constant output.
In testing, the output in a Groovy! has been typically close to 1,200 lux (that compares to about 950 lux with the NG 750 driver).
For somebody with a desire to have a longer runtime with less output, lower output models will become available in the future.
An example of the driver used at a different power level.
Due to the shut-off at about 2.5V, it should be perfectly fine to use unprotected R123s with this driver. The light output will drop like a brick at about 3.45V, so in normal use the battery voltage will never get below about 3.3V because you will know to recharge the battery.
TX0H LED: Price is $40.
All postpaid via First Class Mail to CONUS, foreign orders please add $2 per order. Orders for $30 or over sent with Delivery Confirmation. For insurance or other mail service, please PM.
PayPal cash to: PayCashPal (at) photonfanatic.com
or
PayPal with credit card to: fanatic (at) photonfanatic.com
Those wishing to pay with a money order should send me a PM for details.
Some pics:
or
Some pics:
