Imalent
Page 1 of 3 123 LastLast
Results 1 to 30 of 77
Thread: FS: FluPIC-ES for Aleph Series Lights *SOLD OUT*
    Dec 2004
    Toronto, Canada
    Default FS: FluPIC-ES for Aleph Series Lights *SOLD OUT*
    I'm am building custom ALEPH ES-CAN modules with the FluPIC board. As a part of this service, you can request for a custom UI like BURST -> LOW -> STROBE or some other combination you can think of. Please PM me to talk about the feasibility though.
    I won't go into the details of that this is for but you can search on the forums for the Aleph series lights.
    On level 3/20, I measured around 80ma
    On level 15/20, 500ma
    On burst, 1A
    For $60, you get a ES-CAN all potted with thermal expoxy and a TWOH emitter. Custom programming is included in the price as well.
    Edit: Please add $5 for shipping to anywhere. Delivery confirmation can be added but at a high price. I can not be responsible for lost goods!
    *Lead time is about a week but may drop to 2-3 days if it gains popularity*
    *Flashaholic* CLHC's Avatar
    Dec 2004
    PNW|WA|USA
    Default Re: FS: FluPIC-ES for Aleph Series Lights
    Ho Hey Mai O Mai! Way to go on them FluPic for the Aleph Series Goldserve!
    I'll keep this in mind when I settle on an Aleph soon!
    Enjoy!
    LUX'Ottica
    Dec 2004
    Toronto, Canada
    The aleph is cool!! How about a Aleph 1 and a 2 x cr123 body using a 17670 of course...long and bright!
    Flashaholic* MorpheusT1's Avatar
    Mar 2005
    Norway
    Hey Goldserve,
    Great work there!
    After studying your pictures i noticed one thing that i would recommend you to do.If a McR27 or McR38 is to be used with this setup i would recommend you to use some Nailpolish on the solder points.That is because the Aluminum Aleph1 and Aleph3 Reflectors does not sit on top of the emitter they go all the way over them resting at the bottom.Which may cause in a short if the Reflector touches the points at both sides.
    If this is something you have already done,i am sorry for this post.
    IT is not my intention to make you look bad.
    I just wanted you to know this,it will save you al lot of trouble if the emitters starts to Fry.
    Keep up the good work,
    Benny
    Great job Goldserve !
    I got my custom alternating-strobe FluPIC and it looks great.
    I'm currently making a "can" to fit it in Arc Heads.
    Cheers !!
    Dec 2004
    Toronto, Canada
    Thanks MorpheusT1 for letting me know that is the case.
    Also, I would like to thank CroMAGnet for giving me the motivation to provide the Aleph-ES to you guys and patiently being my lab rat as I try some things out.
    Nov 2004
    UK
    Per PM.
    Please put me down for 2.
    Could you please PM your PayPal and cost of shipping to UK
    Great work
    "I have often regretted my speech, never my silence"
    Flashaholic* jar3ds's Avatar
    Sep 2005
    USA
    dang... this sort of makes 'what surefire KL head should I get' questions rediculous
    awesome... hopefully my Jil Intelli will come today! goldserve... u rule
    Dec 2004
    Toronto, Canada
    I should note that this works very well with surefire's z57 tail cap for the E2L. A twisty is a little harder to operate and as CroMAGnet found out, a two stage aleph switch is just wasting power.
    Do not hesitate to contact me about dumbing down the interface to your liking. It's like mix and match..that simple.
    Nov 2004
    Huntsville, TX
    I already have the e-can and emmiter - would you sell just the board?
    Josh
    Dec 2004
    Toronto, Canada
    Not a problem. $20 for normal sammie sized PCB and $25 for PCB + custom programming. I hope you feel comfortable about soldering and modding cause it takes a little to get it in . Nothing a modder can't handle though =P
    Flashaholic* Icarus's Avatar
    Nov 2003
    Belgium
    Can you point me to the specs of the FluPIC please.
    Nov 2005
    Florida
    Goldserve,
    How would your FluPIC-ES work with my Aleph19, TXOH, MCR91, Wiz2 520ma, 7.5 ohm FT? Would I need to replace the two stage switch to avoid wasting power and what would I replace it with? Does this FluPIC have the same programming capabilities as the FluPIC for the JIL Intelli? I am using 17670s in the A19, it would be pretty cool to be able to make it brighter when I wanted more brightness! It seems like burst mode with the A19 would be a real wall of light!
    Ned
    John 1:5 The light shines in the darkness, and the darkness has not overcome it.
    Dec 2004
    Toronto, Canada
    The Flupic ES will work perfectly in your setup.
    You have a few options to fix your tailcap.
    1. Buy a used SF Z57 tail cap. They are really nice with momentary and clickly on.
    2. Buy a whole new switch from the shoppe without a resistor.
    3. Depending on your switch type, you can get a blank PCB and install 0-ohm resistors and basically short it out.
    I am no expert in all the Aleph series parts so someone please correct me or add to this. thanks!
    Flashaholic* Lunarmodule's Avatar
    Jul 2005
    North Shore Oahu, Hawaii
    Thinking Re: FS: FluPIC-ES for Aleph Series Lights
    I'd be in for a complete assembly but I'm VERY concerned about Morpheus's post regarding 27 and 38mm reflectors. I was planning on using it with a Aleph3 (38mm) head and a Chop custom (with McR16) that takes Aleph LEs. Please let me know if there is a revision made to insure against emitter shorting with the larger reflectors, if so please send me a PM and I'm sold on one.
    Thanks!
    LIGHT TRAVELS AT 186282.397 MILES PER SECOND... ANY FASTER WOULD BE DANGEROUS
    Nov 2005
    Florida
    Quote Originally Posted by goldserve
    I like the idea of the SF Z57 tail cap, but I am guessing that I won't find one in polished aluminum?
    So, as my A19 is polished aluminum, I am guessing that the easiest approach would be to by a new switch without a resistor? Does anyone know what I should look for from the shoppe and how much it costs?
    Dec 2004
    Toronto, Canada
    I did take Morpheus's advice and put some nail polish (sparkly kind... )
    If that still worries you, why not put a piece of tape on the back side of the reflector? Use a knife and cut a hole for the emitter and leave the rest covering the metal?
    How do other people get around this problem? It is not the design of the flupic or anything like that. Seems to be a design problem of the way the es-can and the reflector meets...
    Quote Originally Posted by Lunarmodule
    Thanks!
    Dec 2004
    Toronto, Canada
    Quote Originally Posted by Ned-L
    Maybe you can get someone to strip the HA from a SF tail cap...
    Sorry I don't know anything more about your tail cap options. What are you using now? Maybe it is as simple as taking it out and shorting the resistor on the board already...
    Nov 2004
    Huntsville, TX
    soldering is no problem - If I can do my dorcy board to a homemade ARC board, I should be fine.
    http://candlepowerforums.com/vb/showthread.php?t=107435
    Can you make this work for a 2xR123 setup? I really hope so, otherwise I have to build a new light around it (like I really mind that!
    What I would like as far as custom programing is multi-level, remember which level it was last on for turn on and a strobe set to the max amps and a faster than normal rate - any suggestions how fast? I'm wanting it to be a disorenting tool, like the gladius or whatever it is that is used the same way.
    Josh
    Dec 2004
    Toronto, Canada
    The Flupic board will not work with the 8V as the absolute maximum is 5.0V. However, some 17670s from AW might fit the bill perfectly. You can enjoy longer runtime from the improved battery capacity =)
    Nice work on your mod BTW...
    With a little bit of coding, I think I should be able to accodate your request. The design has everything you need and at 15 hertz strobe, that should be disorienting enough. It may actually take me a week or two to get enough ES-CANS...
    Moderator
    Feb 2003
    CA
    Is the module polarity protected?
    Bill
    Dec 2004
    Toronto, Canada
    No. The design of the es-can might protect against RP because there is no stub on the battery to make contact with the board...
    Flashaholic* HgRyu's Avatar
    Dec 2003
    Seoul, Korea
    My Aleph power pack (2 X CR123a) do not accept protected 17670. (bare 17670 is okay)
    Please be careful...
    Flashaholic* LED Zeppelin's Avatar
    Sep 2005
    Great Lakes
    PM sent with questions.
    Dec 2004
    Toronto, Canada
    HgRyu,
    Thank you for your words of wisdom =D
    Nov 2003
    Belgium
    The Flupic board will not work with the 8V as the absolute maximum is 5.0V...
    Isn't it possible to make a Flupic that works with higher input/output voltages (2x or 3x LIR's)?
    Dec 2004
    Toronto, Canada
    The problem with high voltages, LDO topology is no longer a suitable choice. You'll need some full blow switching type regulator. Given my current schedule with my school project, this will not happen in the short term...
    Dec 2004
    Toronto, Canada
    Sorry for the lack of reply here. I am currently all out of ES-CANS, screw, and pcb part. I am waiting to get some but no word yet. If anyone has a few extras they would like to sell me, please PM me! Thanks!
    Nov 2004
    UK
    Arrived yesterday....works brilliantly. Thanks a million.
