RebelXTNC
I just received a Nuwai Q-3 from Amondotech and it has the non-tactical, reverse-clickie with momentary only after switched on.
Is it certain that this also means it's using the older electronics with lower current drain? Which would actually be ok since it's plenty bright enough. I haven't done a run-time test yet.
However this one is fairly green in LED tint, so I may get another one. I figured all of the older ones would have been out of the supply chain by now unless this was a return due to LED tint. It's not terrible but certainly not white.
Also if I go with the rechargeable lithium-ion, will it make a difference regarding danger to the LED and electronics with the older version or have people been doing this successfully with both versions for awhile?
