Osink, emitter and glue...
sp5it
Poland
Hello. What should I use to place Luxeon3 emitter on Osink?
Thanks, Mike
red_robby
TORONTO
there's a few options out there, any of these
will work.
just a couple of things to keep in mind
are you using a red or red/orange lux (the lux needs to isolated from the sink, better use Arctic Alumina)
do you think you will ever need to "upgrade" the lux? (may want to use something other then an epoxy so you can remove the lux without damage)
sp5it
Poland
It will be white emmiter. Arctic alumina will be good? Only reason to remove will be replacing damaged emmiter to another.
Mike
sp5it
Poland
One more question. Should the diode slug be isolated from osink?
Mike
greenLED
La Tiquicia
If you're using more than one white Lux, you'll have to isolate the slugs. For a single one, and assuming you're also using the heatsink as negative contact, it doesn't really matter.
