Ive drunk water off and on my whole life, but usually flavor it with ice tea, lemonade, gatorage or some other mix. Its not uncommon to see a black spec at the bottom of a glass and I just try not to drink that and pour out the last bit.
Well, the bosses daughter came to me earlier last year when some morning show ran asegment about how bad cola is for you vs drinking water and how much weight you would loose. So, I started drinking raw water than mixing it with the calorie free lemonade mix I normally use.
While drinking I held the bottle up to my computer monitor and looked in the bottom and saw some small oblong things floating around in it that settled to the bottom. I poured it out and refilled the bottle, same thing. Later I went and looked at some other bottles in my fridge and found similar things. I further checked the bottles I refreeze on a regular bases to put on my lower back and neck. Man, when one o those bottles thawed out and I shook it to look at the bottom, it was full of those floating things.
What do you guys think those things are? Part of the bottle floating around in the water?
