vortechs said:
Hi jsr,
I just got 2 JIL's in the mail today. One is a DD Intelli version that comes with a FLuPIC and a TWOH (at least, I think all of the Intelli's were TWOH). The other is a mod created by CPF member goldserve by taking a JIL 1.3W version and removing the micropuck converter and adding one of his FLuPIC's (we're pretty sure the LED is a TWOJ based on what was available when the mod was done). This was one of the prototypes for the Intelli version (which uses the slightly smaller DD form factor). Since they are both effectively DD in burst mode with a primary CR2, I should be able to compare brightness for you, but it will just be my opinion since I don't have any test gear.
Once I've had a chance to try them side by side on CR2 primaries and RCR2 rechargeables I'll let you know my impression of how bright they are. However, if you are really interested in brightness you should get a JIL with a FLuPIC (the Intelli, or one of goldserve's drop in mods for the DD), since that allows you to use RCR's for much greater brightness on burst mode while still offereing increased runtimes on the lower settings. I'll need to find a source of inexpensive CR2 primaries before I attempt anything like try to compare runtimes.
I've noticed that I can't easily compare the brightness of my TW0H Intelli and TW0J (we think) FLuPIC mod. The beams are a bit different, probably due to different reflectors. I believe the original TW0J JIL's used a different reflector than the later TW0H versions. The Intelli has a wider hotspot and a bit more spill while the FLuPIC mod has a tighter hotspot and a bit better throw. I think the Intelli may be a bit brighter overall, but it's hard to tell. I suspect any difference in brightness is due to the variations within the T-bin rather than the different Vf.
My RCR2's just arrived in the mail today and I have a JIL-Cab (2xAA body). I haven't bothered to get any CR2 primaries yet, but since the JIL-Cab with two fresh alkaline AA's (3.0V) should be close to the voltage of a CR2 primary (3.0V), I can compare the 3.0V of 2xAA to the 4.2V of a fresh LiIon RCR2.
The JIL CR2 is usefully bright with 3.0V input and doesn't seem to heat up much. It is much brighter than any single 5mm LED light I own, including the 1xAAA 'chinese eBay clone' and the new "100% brighter" Photon Freedom microlight. It is much brighter than the Princeton Tec Attitude (a somewhat dim but long running 3 x 5mm LED light) and is somewhat brighter than a Princeton Tec Impact XL (an early Luxeon I side emitter). It isn't as bright as the "3 Watt" 2xAA lights from AXShop or the "7w Super Bright Waterproof USA, power 3.6v x 2 charge battery" lights from AXShop. I'd be happy to use the JIL at 3.0V for anything within 20 feet, but it doesn't light up my backyard.
With a fresh RCR2 at 4.2V, the JIL CR2 with FLuPIC in full brightness mode is extremely bright. It is brighter than the "3 Watt" 2xAA lights from AXShop. It is brighter than I'd want to use for close up work, but it lights up my backyard nicely with its wide hotspot. However it does get warm rather quickly. I believe the current is limited by the FLuPIC even in the full brightness mode with a 4.2Vfresh LiIon, but goldserve could clarify this.
Compared side by side, the 3.0V is not as bright as the 4.2V fresh LiIon, but the fresh LiIon doesn't really seem to be 5-10 times brighter (see cones graphs at
http://www.cones-stuff.co.uk/). Perceptually, it seems to be two or three times brighter. To my inexperienced eye, it is like comparing a Luxeon I to a Luxeon III. This may not be a fair comparison for the JIL CR2 DD's performance on a 3.0V CR2 primary, since the JIL-Bus with 2xAA's isn't a CR2 primary.
Hope this helps answer your original question. I would expect the JIL CR2 DD with a 3.0V CR2 primary to be significantly brighter than a KeyMate with a Nichia 5mm LED. I would expect the JIL DD to compare with Luxeon I lights and be perfectly sufficient for indoor or close up work.
