Terralux TLE-100
Bozzlite
Central Texas
Does anyone have information on the TLE-100 Maxcharger3 which is now on the Terraluxbiz website?
It is advertised as a replacement LED for the Mag rechargeable system. Has regulated circuitry and claims 100 lumens with a 6 hour run time.
Wondering if anyone owns one and could confirm the brightness and run time. Also what is the beam like......smooth and even spot, or jagged comet tail etc...
This must be a very new product, since google search turned up nothing.......
not even on Terralux's website. I think I would spend the $34.95 if it passes muster. Even tho, hmmmm, 100 lumens is not much compared to the OEM incandescent, but I like that run time.
greenLED
La Tiquicia
I don't know, that "shock mount" looks like it'd provide a lot of heat isolation/trapping inside the module :confused:
john2551
NY
I'm glad to see it uses a Fraen LP collimator, it produces a nice smooth beam.
BamZipPow
El Paso, TX
I would figure you could put vents/slots/holes in the mount to increase the cooling... :D
john2551
NY
I'm sure they have done testing to make sure it wouldn't overheat.
DiamondLED
WA, USA
Yes, these are brand new and we only got our first samples last week. They've been working on it since I was there last summer. The issue was how easily it fell out when dropped, hence the foam doughnuts. Heat hasn't been an issue and the run times are legit according to our tests. We sell a ton of the NiCAD replacement bulbs for the rechargeable Mags, more than any other bulb by far, they only last an hour or so at best & break when dropped. Just for the savings in battery costs and regular bulb replacements they are worth it in my opinion. We make LED replacements using those same Fraen lenses, good colimated beam, it's a 10 degree, narrow they are using, info here fyi: http://www.fraensrl.com/images/FSG_Lens_Series_Datasheet.pdf
john2551
NY
Steve,
Does this mean DiamondLED will be selling these?
John
L
led_replacement
Guest
Just to let everyone know, I will be selling the TerraLUX TLE-100 when they come out in mid April for $32.95 I have a sample TLE-100 I am testing in a Mag Charger and It looks real good. The beam is bright white with a clean spot with few artifacts. Runtime is about 5 to 6 hours.
Here is a link to the page
http://store.led-replacement.com/yhst-52165116567733/tle100.html
Thanks!
led_replacement
L
led_replacement
Guest
It looks and feels like black foam. Also even when the TLE-100 is on for a long time it does not heat up very much at all.
