The SL35 is bright. The Ultrastinger has a tighter pattern (adjustable). Before I got my 10x, I used the Ultrastinger as my large size light on patrol. If I get an opportunity this week, I will try to create some beamshots for you between the SL20X, SL35X, and Ultrastinger.
One thing to note, the SL20XP and SL20XP-LED (polymer lights) both have 8-watt bulbs. The SL20X and SL20X-LED (aluminum lights) utilize 10-watt lamps. The SL35X utilizes a 20-watt bulb.
The SL35X bulb in the SL20X is actually noted in the Streamlight instruction manual. The only difference between the actual units is that the SL20X utilizes five 1/2 D cells, verses the SL35X contains 5 D cells.
The SL35X was discontinued over 1 year ago.
