PhotonBoy
I've been considering getting a new headlamp for a while now and this one caught my eye at Home Hardware. It was only C$19.97 and you get quite a bit for the few bucks it cost.
Features:
- a reflector around the Luxeon(?) LED
- uses 3 AAA cells in a small carrier shaped roughly like a C or D cell
- 1 red LED above the Luxeon(?)
- a four-position top-mounted switch: Off, Red LED, low output white, high output white. Low is about half the brightness of high.
- the LEDs and reflector are mounted in a small head that can be pointed downwards. There's a plasticky detent system that keeps the head pointed at the desired angle. It sounds kind of loud and scratchy when you move it up and down.
- the housing is similar in size and shape to this light: http://www.dorcy.com/41-2097.htm
The red is actually quite bright, but somewhat blotchy, which I think is typical of red LEDs
The white beam is similar to that of a Fenix L1P, but about half as bright, slightly yellow, a bit blotchy and slightly assymetrical. The LED is slightly off-center but this doesn't appear to affect the beam too much. At close distances, say under 2 - 3 ft., there's a distinct donut hole caused by the reflector.
I'm not sure why Dorcy uses the Reactor name in Canada rather than Dorcy. This seems to have started about a year ago. I'd be concerned that Gerber might come after them; see Gerber's Reactor light here: http://www.gerbertools.com/9016.htm
It's far from being perfect, but for a hair less than $20, I'm happy with it.
Thanks to http://imageshack.us for the image hosting.
