I wish my Stinger HP was brighter.
bascodog
I was wondering if an Ultrastinger Lamp/bulb can be used in a Stinger HP and if so will it make it any brighter. What about a different battery would that help...please someone help.:help:
Flash_Gordon
NC USA
No. The US bulb is 6.3V and your Stinger bulb is 3.7V. Won't fit and would not work anyway. Your battery is only a factor if it is bad or weak.
There are many Stinger mods and upgrades on this forum. A little searching will give you some ideas if you want to upgrade your Stinger.
Mark
powernoodle
secret underground bunker
I just got a HP head for one of my Stingers. Very unimpressive, IMO. It does throw a little farther, which is the whole point I guess, but the regular Stinger is much more useable. Under 75 yards maybe, and certainly at closer ranges, the regular Stinger has a much wider spot and is more floody. At close ranges, the HP is pretty poor, with a very tight hot spot and Mag-like nasty corona full of infirmities. JMO. :nana:
cheers
