ArmyTek
Results 1 to 26 of 26
Thread: Introducing "The One"
    Flashaholic* modamag's Avatar
    Aug 2004
    Bay Area, CA
    Default Introducing "The One"
    Since cmac have uped the ante for the MiniHID world with his 5 Inch Wonder, I have to do the same to the high power LEDs world.
    My son love flashlights, but most of the high power ones in the house is a little too cumbersome for him to handle. So this is my attempt to get something more suiteable for his little hands. A regulated, 1 hr+ runtime, and 200 lumens output light.
    Why you ask this is "The One", well to my limited knowledge there are only a few modded original orange MagLite in the world. And two of them are in the CA Bay Area. This section was the left over of CroMagnet's Mag1D cutdown. To top this off the original lime green head and tailcap. I would have fluted or groove the head if I can find a place can anodize and produce the same shinny quality as the original.
    === Specs ===
    Runtime: 90+ minutes
    Max Light Output: 201.6 - 262.2 lumens
    === Parts List ===
    1x orange MagSD body
    1x lime green head and tailcap switch
    1x FatMan driver (latest version)
    1x PTS2-D heatsink
    3x Luxeon III TY0H
    3x IMS SO17XA reflectors
    1x 4AA-1D battery adapter
    Below is an abbreviated guide of the assembly. A full detail guide is available here.
    ========== Assembly Guide ==========
    Pay special attention to the position of the star alignment. It is configure for series connection.
    Converter and star mounted
    Using a small clamp helps during the potting process. Place a small amount of papertowl between the clamp and converter to ensure sufficient force applied.
    Scruff the anode contact then solder and connect the positive wire.
    Place the negative contact wire underneath the lock ring to provide cathode contact.
    Sweet fruit of our labor.
    double the runtime.
    Who's afraid of the buggieman? I got daddy's light to protect me. No need for nitelite either.
    Canon A80 | Manual | ISO100 | Shutter 1/40s | Aperature F5.0 | Auto White balance
    Flashaholic wtraymond's Avatar
    Mar 2005
    Milwaukee, WI
    Default Re: Introducing "The One"
    Very cool, Jonathan. I'm glad so many have found uses for the SD size. I need to get some of the great clickie tailcap conversions from cmaccel.
    If it doesn't move and it should, use WD-40. If it moves and shouldn't, use duct tape.
    Bill
    Dec 2005
    Belton Texas
    Neat, I did something similar with the MagSD I just got from you. I fitted it with your PTS2-D, shark driver, and three Lux3's. I did the cathode contact slightly differently. I used some #12 solid copper wire bent in a circle around the groove in the anode disc and soldered the wire on to it. The copper wire has just enough "springyness" after bending that it maintains good contact with the bored out body and to hold the adapter in place. But not enough to make it difficult to remove or to fall out of the groove when removed.
    I also built a standard Mag bulb adapter and a hotwire adapter using a Kiu socket. Still not sure which of the three options will be the final choice but I like the versatility. If it wasn't for the fact the I know it's too risky, I would be tempted to go with 3 unprotected Li-Ion 14500's and a WA1185 in the Kiu socket. I know it works cause I couldn't help trying it, but the pucker factor is way too high for me.
    Flashaholic* Lunal_Tic's Avatar
    Jul 2004
    The Wilds of Tokyo
    Cool
    You could also call it the Gatorade Light, it's the right colors.
    -LT
    lunal tic (n)
    a distinctive behavioral trait or quirk directly related to or caused by light [15th cent. Latin lunaris. Ultimately from an IE word meaning “light,”] and [Early 19th cent. Italian ticchio.] see also: moon quirk
    Quote Originally Posted by modamag
    Quote Originally Posted by Lunal_Tic
    Cool
    -LT
    Why? It should be called "Lightneken" instead, Its the same color as the beverage next to it.
    dcarch8
    Jul 2004
    The Wilds of Tokyo
    Just not a beer drinker I guess.
    -LT
    lunal tic (n)
    Flashaholic* Cliffnopus's Avatar
    Jan 2006
    Foxboro, MA
    Great job Modamag. I like the colors, I'll bet your son likes the light too.
    Cliff
    Every normal man must be tempted at times, to spit on his hands, hoist the black flag, and begin slitting throats!
    H.L.Mencken (1880-1956)
    Oct 2005
    Toronto
    Hey Modamag! Great Setup...it looks sweet!
    Quick newbie question: Where did you get that connector? I've been checking all over (hobby shops, and SourceCC), and haven't been able to find any of those bi-pin connectors.
    Flashaholic* russtang's Avatar
    Dec 2005
    BAMA
    NICE! PP ready.
    Nov 2004
    honolulu. hawaii
    sweet!
    Flashaholic* Mini-Moder's Avatar
    Feb 2006
    Maine
    How about doing a run of these? Could do it in all green, no need for the orange. That woud be sweet.
    ~Mini-Moder~
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    Now, that's a light Larry would like.
    Dec 2005
    San Francisco
    Put me on a list. Blue, Purple, Orange, Brown, Zebra, Spotted...... how ever you make them. Let me know.
    frisco
    Mar 2005
    NorCal
    Jonathan: What drive level did you set the Fatman to? I figure around 750mA would be the max on 4xNiMH?
    Flashaholic* missionaryman's Avatar
    Oct 2005
    Sydney, Australia
    Great work Jonathan, you've inspired me to make a light for my son too - his 1st birthday is coming up in less than a month and I was wandering what to get him.
    I think I will revive and mod his Disney aligator light to may be something like a 1W drop in mod...
    "Let your light shine" - it's the one commandment we all obey...
    *Flashaholic*
    tvodrd's Avatar
    Dec 2002
    Hawthorne, NV
    I like your choice of beer! (:finger: -> greenPUNK) Just a hint on the ano. Type II anodize will not cover/hide anything. Sanding swirls, no matter how fine will still be there and visable after anodizing. To have the head redone as nice as stock, I would recommend letting THE PUNK strip it for you, machine your grooves, then polish it to Mag's finish level. Drop it at your anodizer with instructions to rack it from the inside so as not to leave visable rack marks, and hope/pray his dye bath is the right shade.
    Nice light, by the way!
    Larry
    So much for not being able to find my happy a** with both hands and a flashlight! (Do not look into Tank Searchlight with remaining eye!)
    *Flashaholic* CLHC's Avatar
    Dec 2004
    PNW|WA|USA
    Wow! Very slick looking Jonathan! Where can we buy this "One"?
    LUX'Ottica
    *Flashaholic* js's Avatar
    Aug 2003
    Upstate New York
    Very nice! Groovy colors make up for the lack of grooves/fluting in the head.
    -Jim Sexton, creator of the M6-R, the TigerLight Upgrades, Fixture-ring lamp potting, the SL60, co-designer of the B90 Upgrade, and proponent of the SF A2, the SF M6 X-LOLA, Titanium, the Haiku, and the LunaSol 20
    Aug 2004
    down the road from Pleasure Point.
    Great Choice on the choice of beverage, oh the light looks okay too
    "a government and its agents are under no general duty to provide public services, such as police protection, to any particular individual citizen." -Warren vs District of Columbia, after three women were raped, beaten for 14 hours and police never came after numerous 911 calls were placed
    Jan 2005
    Texas, USA, Earth
    Very creative and outstanding execution
    Will
    Please no PM/Visitor Msg's. Email for questions/Paypal: wquiles [at] gmail {dot} com
    Mar 2004
    La Tiquicia
    Quote Originally Posted by tvodrd
    To have the head redone as nice as stock, I would recommend letting THE PUNK strip it for you...
    Modamag, just let me know and I'd be glad to do this for you.
    Great Work as usuall Jonathan
    If anyone has an Orange HOST I want it....
    Mac
    www.macscustoms.com
    *Note* Shipping Insurance must be requested.
    [img]Since cmac have uped the ante for the MiniHID world with his 5 Inch Wonder, I have to do the same to the high power LEDs world.
    Hmm Maybe an Nflex "WYOS" in this baby!
    Are we in competition now
    Mac
    www.macscustoms.com
    *Flashaholic* KevinL's Avatar
    Jun 2004
    At World's End
    I like the first picture of the light and the beer too....
    Celebrating the ROP.. 5 years of history
    *Flashaholic*
    tvodrd's Avatar
    Dec 2002
    Hawthorne, NV
    (Hijack alert!) At the hotel I stay at in Providence, RI, (again next week ) there's a sign across the road in front advertising Heinekin Light! Anybody tried one yet? (Hasn't made it to the left coast yet.) I did my own once:
    (pk bought me that beer at the Sequoia get-together some years back. )
    Larry
    Flashaholic sp5it's Avatar
    Feb 2005
    Poland
    Can you post more information how to put switch in the tailcap? I`m gonna build cutdown 1D Maglite, and more information will help a lot.
    Thanks, Mike
