andrewwynn
When i bought a 3D and 4D mag host recently a minimag came with it. Well I wanted to put an LDO^3 driver and use some of those AA primaries i bought in there but the voltage was a bit too low. I think i have a next-gen driver that would have worked, but instead i realized that a Lux-V should work out ok with an LDO^3 driver.
The results:
This is a groovy using the LDO^3 driver and a McR18 reflector.. output.. maybe 1000 lux center... guessing about 80-90L
This is the MiniMag-V using a LuxV driven to about 1A.. (varies to keep light output more constant.. outputs more mA if it's warmer). Notice the donut hole? neither do i. I'm using an IMS20 reflector, and de-tuning the reflector a bit it virtually eliminates the donut hole.
Trade-off.. not as much beam center lux.. but it does output more total lumen.. though as a 'tester' i used a lower output LuxV and is probably less than 100L.. i didn't want to blow an expensive luxV on the trial model.. now that i know it works i'll get some nicer LuxVs.. it is such a gimme mod!
Side by side:
The rest of the beamshots (incl. the 3-levels of groovy) are here
-awr
The results:
Side by side:
-awr
