ArmyTek
Page 1 of 34 1234567811 ... LastLast
Results 1 to 30 of 995
Thread: Spectrographic charts
    *Retired* The_LED_Museum's Avatar
    Aug 2000
    Federal Way WA. USA
    Talking Spectrographic charts
    This thread will be for spectrogtaphic charts of various LEDs and lasers.
    I have temporary custody (loan) of an Ocean Optics USB2000 spectrometer.
    Let's start off here with the first one...
    This is the white LED used in the older style Arc-AAA LE (PE).
    Aug 2000
    Federal Way WA. USA
    Default Re: Spectrographic charts
    This is for a DPSS green laser.
    Aug 2000
    Federal Way WA. USA
    This is for a stable phosphor-type pink LED.
    Aug 2000
    Federal Way WA. USA
    This is for a blue DPSS laser.
    Same as above, with IR filter removed.
    Aug 2000
    Federal Way WA. USA
    Red LEDs from a PowerFlare.
    Aug 2000
    Federal Way WA. USA
    Directly-injected red laser diode.
    I'll do the DPSS yellow laser later today.
    May 2002
    Maui
    Let me add a couple:
    SF M1 Ir:
    Aug 2000
    Federal Way WA. USA
    Spectrometer plot of the yellow DPSS laser I have.
    Same as above; IR filter removed.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a GE AR-1 argon glow light blub.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a 385nm UVA LED.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a white Luxeon Star I LED.
    *Retired* NewBie's Avatar
    Feb 2004
    Oregon- United States of America
    Luxeon LXHL-BW01 spectral shift due to current dimming:
    Luxeon LXHL-BW01 spectral shift due to pwm dimming:
    60 Watt Incandescent:
    Two different luxeon bins:
    Toyoda-Gosei True-White-Hi long life blended Phosphor w/UV LED source:
    Luxeon III QX1J #1:
    Luxeon III QX1J #3:
    The X1 bin is very large, the difference in color appearance of the above two:
    American Bright Opto BL-HX136D:
    American Bright Opto BL-HJB36D:
    American Bright Opto BL-HKD36D:
    American Bright Opto BL-HG636D:
    American Bright Opto BL-HA136D:
    NEC Monitor:
    Tri-Band CCFL from Laptop:
    Nichia NSSW440T:
    Vishay TLMB3106:
    Peak UV Flashlight:
    CREE XL7090 Red:
    CREE XL7090 Blue:
    [img][/img]
    Apr 2002
    Boise, ID
    newbie,
    nice graphs. I noticed that the batwing Lux I (BW01 - globbed phosphor batwing) you tested has the "red spike" in the spectrum, while the Lux III samples don't. Looks like maybe the phosphor is indeed different between these two generations of Luxeons.
    Craig's Lux I test has the red spike, while McGizmo's Lux III again does not. So it does indeed look like there is a phosphor difference.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a white Luxeon Star III LED.
    Aug 2001
    VA
    Sunlight anyone?
    Light is the activity of what is transparent - Aristotle
    Flashaholic* Quickbeam's Avatar
    Jun 2001
    FlashlightReviews.com
    Sunlight? Here you go! Not as perfect a spectrum as you may think!
    Full Solar Spectrum
    OK, so it's not a true spectrographic chart, but I think it belongs here anyway...
    Enjoy!
    Doug P.
    Archive of the Original FlashlightReviews.com ::::: The default position on any claim is disbelief until credible evidence is presented.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a white Luxeon Star V LED.
    *Flashaholic* PhotonWrangler's Avatar
    Oct 2003
    In a handbasket
    Nice graphs, Craig!
    Have you tried varying the current (or putting in a weaker battery) on one of the red lasers and noting the results? I've found that the spectral content spreads out when it's not driven as hard, and when the current falls below lasing threshold, the spectral content looks virtually identical to a red LED. It's kind of interesting to compare the spectral width at different drive levels.
    This phenomenon matters when using a directly-modulated laser for fiber optic communications when using amplitude modulation, as the spectral width of the laser jumps around a lot from the modulation.
    Veni vidi velcro
    Aug 2000
    Federal Way WA. USA
    Yes, you are very correct here; when the drive current to the laser diode is below threshold, the spectral line halfwidth increases DRAMATICALLY, causing the laser diode to have an emission spectrum very similar to that an LED would generate.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a 400nm LED.
    Aug 2000
    Federal Way WA. USA
    Spectrometer plots of the four LEDs in an eternaLight Rave'n X2:
    Spectrum of the red LED.
    Spectrum of the yellow LED.
    Spectrum of the green LED.
    Spectrum of the blue LED.
    Aug 2000
    Federal Way WA. USA
    Spectrum of a 3 volt incandescent light blub.
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    Cool. Do one of your Cyan "positron laser" please!! I want to find out what bin it is!
    Aug 2000
    Federal Way WA. USA
    Your wish is my command...
    Spectrum of the cyan Luxeon V in my Positron Laser flashlight.
    Jan 2003
    Missouri
    Thanks! So is that 490nm? Hard to tell exactly what it is. Do you know exactly what the peak is? The colors around those wavelengths vary a lot with just a couple of nm.
    EDIT: Unless your instrument gives the actuall peak number, what I determined from drawing a line in photoshop was 488nm!! Argon laser color exactly!!
    Oct 2003
    In a handbasket
    Quote Originally Posted by The_LED_Museum
    Thanks! Now that's a perfect explanation of why a filtered incandescent bulb makes such a crummy blacklight. There ain't nuthin' there!
    Veni vidi velcro
    Jan 2003
    Missouri
    yeah, no wonder those things get hot! It's absorbing all the engery made by the bulb!!
    Aug 2000
    Federal Way WA. USA
    Quote Originally Posted by IsaacHayes
    As far as I'm able to determine, the peak wavelength of that LED is between 491nm and 494nm.
    Let me go examine that spectrum a little more closely and see if I can pin it down with any more accuracy...BBS...
    Ok, looks like ~492nm to me.
    Visually, from what I remember, the light from the Positron Laser is *JUST A HAIR* more greenish than the 488nm argon-ion laser.
    Jan 2003
    Missouri
    Cool, sounds like you nailed it then. ~2-4nm is visable probably when compared side by side. Do you find the side-spill when cast on objects like wood/skin/etc or stuff at a distance looks more green than the center hotspot? I found that once you get to 488nm it all looks "light blue" and that effect goes away.
    Aug 2000
    Federal Way WA. USA
    I think the corona light appears to be the same color as the hotspot; but I don't have access to forested areas or dark distant areas here, so I can't take it into dark woods or dark parking lots to see how objects appear in this light to confirm these findings for you. :
