Fenix L1P unscathed by Washing Machine
wasBlinded
Oklahoma
Just got back from a caving weekend and threw the muddy clothes into the washing machine. Thought I had everything removed from pockets, but the L1P (one of the backup lights) eluded discovery and went through a long cold water wash. When retrieved from the washing machine (still in its sheath) it was cold and wet, but lit up just fine, and there is no sign of water in the head or battery tube. Very nice little light!
greenLED
La Tiquicia
time to repeat with hot water ;)
...then add some bleach
It really is cool to know the lights you have can take abuse like this.
Flash_Gordon
NC USA
I carry my L1P in the coin pocket of my jeans. As careful as I try to be with pocket checks, mine recently had a warm water wash.
Came out very clean with no water inside. Obviously well designed and well made.
Mark
DonnyD
Fayetteville, New York
I saw that you put your L1P through the wash and I wondered if you or anyone else sees the black finish wearing off? Mine has faded all over. NOw it's black on the ends with a faded middle section.
I just wondered because my newer L2P seems like it has a better finish and thought fenix may have improved the finish on all their lights.
The fenix doesn't take a beating especially well, but it's tough enough and modified or not, Johnny Cash Black or a bit faded, this is a nice light.
srvctec
Central USA
Although mine has not made the trip through the wash yet, the finish on it is unbelievably tough- just like HAIII should be. I think there is a lot of variation between quality of anodizing on these lights as I've seen numerous posts regarding poor quality HAIII when mine is tough as nails.
An example with mine: I installed a pocket clip from a Gerber Infinity Ultra (the old style extremely stiff spring steel) on my L1P. In the process, I had to remove and install it 6 or 8 times trying to get it adjusted properly. The surface of the HAIII had marks on it but never scratched through.
phosphor
Puget Sound, WA.
...you'll get a softer spill beam if you run the little Fenix through the dryer with a sheet of fabic softener !
wasBlinded
Oklahoma
Fortunately, I was smart enough :whistle: to leave the L1P in its sheath when I forgot about it and washed it, so not much opportunity for cosmetic damage. The exposed edges of the button end show no wear from the tub, though.
DonnyD
Is that blue ball next to your name located somewhere in your house? 'Cause it's very cool, and I am guessing it might have caused the finish on your lights to set in better than for CPF'ers who, for instance, don't have the ball.
Seriously, I'll bet you are right on about the variation. My newer L2P is darker black than the L2P ever was, I am almost positive, anyway, and it feels better.
I think it is telling that you used the word "unbelieveable" to describe the finish. I believe it, so there surely is a range of quality.
DonnyD
That was a good move to leave the cover on
. Even so, it sounds like some fenix, like yours, for instance, are tougher than others, or they have been improved. Should I buy another, and compare?
srvctec
Central USA
Buy a couple more- it's the CPF mantra!:grin2:
