I bought a 12AA-3D adapter kit from Modamag so I could make a battery pack for awr's MAG138 monster. I needed a jig to hold the PCB boards parallel while I soldered the rods to the lower 2 boards. I came up with the idea to use a piece of angle aluminum and cut slots in it to hold the boards. To cut the slots I just used my Dremel hand piece to lay in the V of the angle so each cut was perfectly perpendicular to the angle piece. The Heavy duty cut-off wheel is about the same thickness and diameter as the PCB board. Now I have a jig to make a few of these.
I made an ACAD drawing of the adapter first to figure out what distance all the boards needed to be at. I then printed it out, cut out the PCB boards on the paper and laid it on the angle and marked the angle with a sharpie. Now I know where to make my cuts! The same can be done for all the battery adapter sizes. This particular one I made is just for the MAG138 because the springs had to be removed and the top PCB board is bolted down to the top of the batteries just how awr specified.
Someone has probably already done this, but I have never seen it posted anywhere. If the links dont work then just go here then to my photos/battery adapter jig.
Thanks to Modamag & awr I probaly would have never tried to solder my own battery adapter together & got me thinking on how to make it work!
