Hello GarageBoy,
It depends on what the charger uses as a charge termination condition.
If it is timer controlled, and you start with empty batteries, and it charges at a rate that is compatible with fully charging the batteries, it will work fine. If it charges at a slow rate, your batteries will be under charged. If it charges at a slow rate and your batteries are only partially discharged, it will cook them.
If it uses temperature control, you should be fine, within the limits stated above.
If it uses peak voltage to terminate the charge you should be fine, within the limits stated above.
If it uses - delta V, you will cook your cells.
I believe Sanyo ran a test on what happens when you charge NiMh cells on a NiCd charger that terminates on - delta V. They found that the NiMh cells heated up (cooked), but did come to a full charge state. The effect of this overcharging reduced the cycle life from around 500 charge/discharge cycles to somewhere around 20, if I remember correctly. At any rate, it was a drastic reduction in life cycle performance.
In order to answer your question, we need more information...
Tom
