FrogsInWinter
Just got my new Inova T4 this morning. This is one impressive light. I'd say its pretty comparable to my Stinger HP. The center hotspot is whiter than and about as bright (maybe a little less) than than the Stinger HP when tightly focused. The T4's spillbeam covers about the same area as the Stinger HP set to flood. All that without ever having to adjust the T4, well you can't adjust it but you get the idea. The look, design, and feel of the T4 just ooze quality, even the box it comes in reflects this. The two hour runtime just makes a great light even better
. However I would like a good sheath or belt holster for my new light, and the option of a tailcap switch would make the light more attractive to customers.
A few things I've noticed so far:
- A friend of mine removed to tailcap to look at the rechargeable battery. After replacing the battery and tailcap, the T4 would not light up. After removing and replacing the tailcap a few more times and clicking the mid-body switch several times, the light finally turns on.
- When I tried to charge the light for the first time, the indicator light on the charger cradle did not light up. After a few minutes of making damn sure the light is sitting properly in the cradle and several clicks later, finally the charger light lights up, at last recognizing the flashlight is there.
- The manual says that when charging, the indicator light is a steady blue. When fully charged (which can take up to 3 hours), the indicator light turns green. However after 3 hours I see a blinking blue light instead of a green light.
Any other T4 owners experience any of this? Great light though, no buyer's remorse here!
Beamshot pictures to follow soon!
