Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
SilverFox said:Hello Handlobraesing,
If you are using a charger that terminates with 10-15 mV per cell - delta V, you are using old technology. The current chargers are using 3-5 mV per cell.
Another thing to keep in mind is that our newest high capacity batteries only have a life expectancy of 300-500 cycles.
Tom
I can't view the pic or whatever it is in the #1 post from my wireless connection.koala said:So who would take up the challenge to replicate the test condition on today's cells? :naughty:
HeHe, finally a much needed a real observation!eluminator said:I don't think there is one "best" solution. My charger uses a combination of things including dV²/dt² and -dV. It also reduces the current near the end of the fast charge. It does not use temperature however.
Temperature would probably be a good method if the temperature could be sensed reliably. I don't know if that's the case.
Like others have said, 100 charge cycles is a lifetime for some applications. I charge the cell in my Arc AAA light about every two months. 100 charges would be 16 years. Already the cell I use is outdated, not to mention the flashlight.
Of course if I could get 1000 charges out of the cell that would mean I would live for over 160 years. I'll have to work on that.
wptski said:I can't view the pic or whatever it is in the #1 post from my wireless connection.
What charger "only" uses Dt/dt for termination? User's here are quoting from Battery University about today's chargers a combination of all termination methods plus temperature and time backup. Where are these superduper chargers at??
Since what I've read and can remember, Dt/dt termination method occurs at higher charging rates. NegDeltaV occurs just several minutes after Dt/dt. Doesn't seem like much of a lifesaver.
Oh yeah, I think that person that started the post should do the testing too.
Erasmus said:Can anyone translate in human language which is now the best advice for people using NiMH cells?
Have you forgotten the Quest Battery link? They suggested against using the most widely used form of termination, -DeltaV! So are they correct?Handlobraesing said:It's better to go by the data provided by credible publishers who gathers data from various first hand sources. You gotta realize corporations like Duracell have a fully stocked lab with calibrated customized instruments that are capable of conducting the experiment with consistency. Reputable companies typically rate their products using the industry standard method too rather than using some peculiar methods that is meant to make their products have good number under their optimized test.
I question the Battery University suggestion that "today's" chargers use a combination of -DeltaV, 0DeltaV, Dt/dt, temperature sensing(whatever that is?, maybe they mean temperature cutoff?) and timed cutoff! What chargers do all that?Brighteyez said:If your insinuation is that the content on batteryuniversity.com is of some fly-by-night origin, you may want to look a little further into the resources behind that site. If you'll take a look at http://www.cadex.com/, (the corporate site behind batteryuniversity.com) you'll probably find that Isidor Buchman might just know a little bit about battery charging and conditioning. Probably a bit more than the folks at Gillette who aren't really in the business of making rechargeable batteries or chargers. I'd be more inclined to think that chargers and batteries under the Duracell branding are sourced solely from OEM/ODM vendors rather than being developed by either Duracell or Gillette.
