Phaserburn said:
It's actually not all that sophisticated. It's a buck circuit; they have a very flat output when sufficiently over-volted.
It's not a simple dropper buck circuit. When you decrease the voltage, it draws more current meaning that it doesn't get less efficient as the battery voltage gets higher.
With a 0.1 ohm shunt in series and my frequency counter connected across the shunt, it detects around 100KHz which means the circuit is a switching regulator, which offers better efficiency over the full range of battery voltage.
This circuit can be useful for using it in conjunction with a Luxeon Star for other sutff. The real question is what IC is used for PWM control.
If nobody has done it, it could very well mean I'll have to buy another one and go at it with a drill and a Dremel until the driver circuit is exposed.
